[SOLUTION] "Accept incoming connections" every time qBittorent is opened
Re: [SOLUTION] "Accept incoming connections" every time qBittorent is opened
I'm also in Big Sur and the solution is not working ("no such directory" even if it exists!!!)
Dude, thank you so much. Works on Big Sir 11.4. June 2021Rainmaker wrote: Sat Nov 05, 2016 12:36 amthenCode: Select all
cd /Applications
sudo codesign --force --deep --sign - ./qbittorrent.app
Just wanted to show that it worked for me. I am not a mac expert, hence the clunky screenshot. Your screen output could vary as I had already run this command. Also if you have a blank password setup, you won't be able to get into "sudo." Just make a dummy password (12345 or something) for the command and change it back when you are done.yannisgk wrote: Fri Apr 23, 2021 7:35 am I'm also in Big Sur and the solution is not working ("no such directory" even if it exists!!!)
https://imgur.com/gallery/p1uXpcs
Confirming that it worked on 12.5.1 on M1 Air. Thanks.
