[unofficial]qBittorrent git master builds: 3.2.0beta_20150329_c6bfcd0
Herrn Jensen
Re: [unofficial]qBittorrent git master builds: 3.2.0beta_20150329_c6bfcd0
Post by Herrn Jensen »
Thanks, that helped, the extra trackers are gone now.
Is it a new option, or what is changed, since they did not appear in any of the previous versions. Or were they just not displayed.
And I have not seen it with other torrent-programs.
bloodybunny
Post by bloodybunny »
Can someone confirm if "Last Activity" column resets size on client restart ?
I think that the stable release from v3.2.0 is very close, all issues have been closed at the milestone page!
Edit: 1 open :P, got excited too early ::). But still close for the stable.
tekko
Post by tekko »
When u uncheck the tracker list on the left panel, does qbt still do the filtering behind the scene? I was trying to save some resource since I don't need it. It would be nice if the feature gets disabled totally when unchecked.
tekko
Post by tekko »
I think it's still safer to go with libtorrent 0.16.x for the next stable, even though u guys r trying to phase it out. On my xp system, libtorrent 1.0.x is less responsive.
mp
Post by mp »
[quote="tekko"]
I also get higher cpu-usage under XP, but 3.2.0 beta is running stable (i.e. keeps transmitting and receiving over serveral days), whereas 3.1.12 stalls after a day or two. So yes, I would like the ui to get more responsive, but a solid working engine in the background is more important to me.
tekko
Post by tekko »
Unless the gui/cpu part is improved, I'd suggest stable build with 1.0.x and special build with 0.16.x (or the other way around). Special builds being available in the forum to lessen the confusion?
Gúgolplex
Post by Gúgolplex »
And a build with QT5 and 64 bits
lev
Post by lev »
I had some crashes in the alphas on Win 8.1 x64:
Faulting application name: qbittorrent.exe, version: 3.2.0.0, time stamp: 0x54fb81dc
Faulting module name: ntdll.dll, version: 6.3.9600.17736, time stamp: 0x550f42c2
Exception code: 0xc0000005
Fault offset: 0x00049031
Faulting process id: 0x878
Faulting application start time: 0x01d07ef2cf1e378a
Faulting application path: C:\Program Files (x86)\qBittorrent\qbittorrent.exe
Faulting module path: C:\windows\SYSTEM32\ntdll.dll
Report Id: 06dc8c21-eaf1-11e4-8276-bc5ff4b01d2c
Faulting package full name:
Faulting package-relative application ID:
Faulting module name: ntdll.dll, version: 6.3.9600.17668, time stamp: 0x54c846bb
Fault offset: 0x00042bad
Faulting process id: 0x179c
Faulting application start time: 0x01d07484a9b94fd9
Report Id: 99ca2aeb-e12a-11e4-8273-bc5ff4b01d2c
I just noticed the beta.  I installed & will test.  Is it already fixed or is more info needed?
lev
Post by lev »
Yikes it happens in beta too:
Faulting application name: qbittorrent.exe, version: 3.2.0.0, time stamp: 0x5518450c
Faulting process id: 0x1250
Faulting application start time: 0x01d07efdf9ced62a
Report Id: ddb1cd61-eaf3-11e4-8276-bc5ff4b01d2c
It's pretty easy to reproduce by adding / removing trackers while a transfer is taking place
