Hi sorry my English but I write with the google translator, I have a problem with my qbittorrent for imac, when I try to change the download folder and store it with ok as soon as I exit the settings, it returns the folder file from before I can't to change it, someone could kindly help me.
I tried to install a previous version and it works, the problem persists only with this version, unfortunately I cannot use the previous one for administrative reasons.
Version 4.4.2 (64Bit)
I am attaching an image file.
Thanks Bengi
Change download file destination
- Schermata 2022-04-16 alle 11.39.10.png (17.65 KiB) Viewed 2487 times
- Schermata 2022-04-16 alle 11.25.32.png (92.57 KiB) Viewed 2495 times
Re: Change download file destination
There are some problems with 4.4.2, try to use 4.3.9 until 4.4.2 is fixed.
It is a bug that many have reported.
We are all waiting for a fix.
