Can't change path for "Incomplete torrents"
Deexzzz
Post by Deexzzz »
Hi
I've tried numerous times, but I can't seem to change the path for "incomplete torrents"! (please see screenshot)
I'm wanting the downloads folder and a different internal drive to my OS. I manage to change the other locations, but everytime I open the program or the options, it's changed back to it's default download path.
Any idea what's going on and how i can successfully change this path?
TIA
wpburrows
Re: Can't change path for "Incomplete torrents"
Post by wpburrows »
i am having the same issue...
the workaround i use is to use categories, and assign the categories incomplete torrent path to the preferred path... not perfect, but it works.
Deexzzz
Post by Deexzzz »
Okay great I'll try it ... hope they fix that issue!
Deexzzz
Post by Deexzzz »
wpburrows wrote: Tue Apr 26, 2022 8:04 am i am having the same issue...
Actually after looking at it and trying, I can't work out your work around ... could you please give more instructions
wpburrows
Post by wpburrows »
create a category... like "movies", or whatever....
then right click the category in the left pane... edit category
now you can use the dropdown for the incomplete torrents, move it from "default" to "yes" and enter the path you want
qbittorrent categories.PNG (19.44 KiB) Viewed 2195 times
