speed problem 20 mbs max
jimlogan60
Post by jimlogan60 »
Hi All, I'm running qB latest build with a paid VPN over FiOS. A speed test with the VPN running (and qB not running) shows about 200 mbs up and down. I get only a maximum of about 20 mbs download of all torrents combined when running qB in spite of tweaking all the settings as suggested here and elsewhere. Any ideas? Thanks.
Gripweed107
Re: speed problem 20 mbs max
Post by Gripweed107 »
Classic bit confusion. QBitTorrent measures in MiB/s (mebibyte/second) when dealing with the kind of speed you are talking about. If your VPN over FIOS is actually using the measurement of Mbps (note the small b and no i) then that is something quite different.
1 MiB/s to Mbps = 8.38861 Mbps
So, 200 Mbps divided by 8.38861 equals 23.8418522258 MiB/s which is pretty close to the 20 MiB/s you say you are getting on QBitTorrent.
