"Errored" for some torrents.
oldaccountspruned
Post by oldaccountspruned »
Is there any way to pull a log and identify the precise error from this?
oldaccountspruned
Re: "Errored" for some torrents.
Based on some googling, this may be an issue, writing to SMB paths. Is there a known fix for this?
I used to previously but I changed how my setup works.
KDAM71
Post by KDAM71 »
I have the same problem. Did you find out anything more about this?
Click the affected torrent, Trackers tab on bottom and see what's the issue.
swigyfood
Post by swigyfood »
Hello
Yes, you can pull logs in Qbittorrent to identify errors:
Enable Logging: Go to Tools Options Advanced and enable logging.
View Log: Check the Execution Log tab or locate the log file in the Qbittorrent settings directory for detailed error messages.
ticedoff8
Post by ticedoff8 »
SMB is limited on the characters and length of the file names.
There will be some special characters that will cause that error or the length of the filename
It happens a lot when using Windows as the qBt host. I ended up having to edit the file name to get rid of special characters or shorten the name.
I assume this will happen with the Linux based qBt when the download directory is a CIFS share.
