I'm running on a server with an ssd and hdd, my default path is the hdd, everything that gets sent there gets automatic torrent management, however, things that are sent to my ssd, a custom path I guess you could say, through an autodl type program, do not have automatic torrent management ticked, which means I can't run cron jobs to move categories later automatically, I have to tick the box to turn on automatic torrent management for these problem torrents and then move categories and that's grunt work.
I figure a script to turn on automatic torrent management mode on completion would fix the problem but I don't know any scripting, but shouldn't be too hard, then things should work smoothly with qbit cli and category moving and cron.
any help much appreciated thanks.
