It would be nice if we could have a toggle to change the file size viewed on MetaData before downloading a Torrent to Decimal (kilobytes) from Binary as Windows uses Decimal.
So you can compare if you already have the file by size.
Option to change view of File Size from Binary to Decimal
Re: Option to change view of File Size from Binary to Decimal
Are you sure about that?
Windows shows sizes in power of 2 units, kilobytes, megabytes, gigabytes as per JEDEC standard. I prefer it that way, and wish qBittorrent would just use the standard KB, MB and GB suffixes the same as Windows does.
