Please add the ability to have multiple tabs/profiles in qBittorrent.
There will be tabs and you can have one tab and add/remove as many tabs as you like. These tabs are profiles. Each tab will be running in the background by downloading and uploading torrents. However the settings can be different for each profile. For example Profile 1 can use a proxy server while profile 2 uses a different proxy server.
The use case of this for me is that my VPN provider allows you to reserve certain port numbers for forwarding on all VPN servers, and by having profiles in qBittorrent, one can have a profile for downloading and seeding public torrents, another profile for downloading and seed private torrents with friends and family, and so on. By having multiple profiles and having each profile using a different port number, I can increase my privacy from torrent trackers by splitting up my torrenting into different port numbers.
Profiles can be setup to use different proxy servers for each profile for increased privacy from tracking.
