Add option to remove options from system tray right click menu (especially 'resume all' and 'pause all')
lastninja
Post by lastninja »
I have thousands of torrents, mostly seeding but some that are 'to be downloaded possibly one day on a rainy day'. Hundreds of those.
I migrated from utorrent to qbittorent recently. And I've been enjoying it.
But, when going to the system tray to right click and 'exit' the other day, I accidentally clicked 'resume all'.
This caused hundreds of torrents to start downloading that I didn't want to.
I had to quickly rush to stop/pause them all so that I didn't download lots of stuff I didn't want right now, and then delete the incomplete files after that.
I would love for an ability in settings/options/advanced options to modify the system tray right click menu. At the very least, to remove the options for 'resume all' and 'pause all' as these are settings I will NEVER use and will only cause me grief if I accidentally ever press them.
p0rta1
Re: Add option to remove options from system tray right click menu (especially 'resume all' and 'pause all')
Post by p0rta1 »
That should be solved with confirmation modal window.
lastninja
Post by lastninja »
Are you saying there should be a confirmation request when you click it, to confirm if meant to click it?
p0rta1
Post by p0rta1 »
I'm saying propper solution to your problem would be adding confirmation dialog window to confirm "resuming all". Currently there is no such feature.
You can ask for such feature on https://github.com/qbittorrent/qBittorrent/issues (as very first message in this forum branch says).
Beside that quicker solution might be turn off displaying QB in notification area.
lastninja
Post by lastninja »
I have made a suggestion on the github but will update it with the idea for confirmation
lastninja wrote: Fri Sep 23, 2022 4:35 am I have made a suggestion on the github but will update it with the idea for confirmation
Could you link the issue on Github?
lastninja
Post by lastninja »
Peter wrote: Tue Oct 25, 2022 10:07 am
https://github.com/qbittorrent/qBittorrent/issues/17683
This has been merged since.
The core "issue" is still there, the support for a proper pause. I said I'd look into it and I have not forgotten, I just have to work on some other projects right now, but I'll try to come up with something. While hopefully not burning out the team once again with my horrible PRs. :)
