strange message
marcosau
strange message
Post by marcosau »
How could I solve this problem:
"Error: There are not enough system resources to complete the requested service.
I use Windows 11
PriitUring
Re: strange message
Post by PriitUring »
Google Search shows that you are low on RAM.
Did you disable Windows pagefile?
Did you modify any advanced RAM usage or Disk Cache settings?
Did you try newest qBittorrent v4.4.5 or v4.5.0beta1 using 32-bit or 64-bit installer?
marcosau
Re: strange message
Post by marcosau »
Windows pagefile ---> It has not been deactivated.
Disk Cache ----> It has not been deactivated.
