Can some regular expression expert please tell me what expression I could use to download the TV show called "From" without getting every single tv show that starts with the word From? Like "From Scratch" came up today. I have tried to create an expression and tested it on an online tester but it didn't work in qbittorrent so I'm asking for help. Thank you very much in advance.
The ones I want look like this:
From S01E10 XviD-AFG
the one I got that I didn't want looked like this:
From Scratch 2022 S01E07 XviD-AFG
thanks again.
d
regular expression
Re: regular expression
I am anything but an expert...
So regex is not that hard (says the person who never mastered it).
Basically...
From S01.*
- So anything that starts with "From S01" will match.
If you give more examples, I'll try to post more to show how it works.
If you want the next season when it comes out from.. "From", then you can do:
From S[0-9]+.*
- "From S" start
- [0-9] numbers and there is a + after the "group", which means one or more of these 0-9 numbers (ie.: S01, S1, S99)
- and finally: .* - which will match any other character
If you want only from this AFG group:
From S[0-9]+.*AFG.*
- "From S" start
- then .* which just means anything can come now
- AFG: the group you want
- .* to finish it, because there might be anything after
