[official]qBittorrent 4.5.3 installer - Built with MSVC 2022
Link to 4.5.3 post-> viewtopic.php?p=40743#p40743
*****ORIGINAL POST BELOW****
Here is qBittorrent 4.5.0 built with MSVC 2017 and 2022(the qt6 installer).
4.5.0 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.2.18+gitcd05e947f6 / 2.0.8+git64817e0e87
Qt: 5.15.7 / 6.4.0
Boost: 1.80.0
PS: For anyone wondering, I didn't use Qt 6.4.1 because of this bug: https://bugreports.qt.io/browse/QTBUG-108593
Re: [official]qBittorrent 4.5.0 installer - Built with MSVC 2017/2022
Nice release with great improvments and changes, thanks sledge and everyone involved at Github. It takes alot of energy, patience and time to make such a release happen.
Zoloft
Post by Zoloft »
Appreciated!
Re: [official]qBittorrent 4.5.1 installer - Built with MSVC 2017/2022
Here is qBittorrent 4.5.1 built with MSVC 2017 and 2022(the qt6 installer).
4.5.1 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.18+gitd22612ca1b / 2.0.8+gited3c8a920e
Qt: 5.15.8 / 6.4.2
Boost: 1.81.0
Re: [official]qBittorrent 4.5.2 installer - Built with MSVC 2017/2022
Here is qBittorrent 4.5.2 built with MSVC 2022(all installer versions).
4.5.2 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.18+gitd22612ca1b / 2.0.8+git06f98369cb
Qt: 5.15.8 / 6.4.2
Boost: 1.81.0
Goodman07
Re: [official]qBittorrent 4.5.2 installer - Built with MSVC 2022
Post by Goodman07 »
Hello,
I have a question for the developers. I see there are four distinct installers for qbittorrent
1- Qt-5/LT-1.2
2- Qt-5/LT-2.0
3- Qt-6/LT-1.2
4- Qt-6/LT-2.0
I understand the differences between all four, but my question is;
Which one is the default installer? or which installer is the one recommended and used by the developers themselves?
Since the qbitorrent client performance is slightly different in each version, I would like to use the one that is used/recommended by the developers themselves.
And a request to please make one installer the default installer in future releases, while providing the other three as additional options to people who want to use them. This way everyone will know which one is the recommended version and which ones are optional.
Thanks,
Goodman07 wrote: Mon May 08, 2023 2:48 am Hello,
1- Qt-5/LT-1.2
2- Qt-5/LT-2.0
3- Qt-6/LT-1.2
4- Qt-6/LT-2.0
Thanks,
You can assume as default the ones that the updater detects: The Qt5 build with LT-1.2
I use the Qt6 version with LT-2.0. AFAIK the other main devs do the same.
If you're on Windows 10+ there's not point in using the Qt5 version. In fact, it will be dropped in v4.6.0 (alongside Win7/Win8 support).
You should start with LT-2.0 and if you observe unreasonable memory hogging then try the LT-1.2. LT-2.0 is probably fine for the average user.
Here is qBittorrent 4.5.3 built with MSVC 2022(all installer versions).
4.5.3 link-> http://www.fosshub.com/qBittorrent.html
Libtorrent: 1.2.19+gitadac0d0843 / 2.0.9+git73089332ab
Qt: 5.15.9 / 6.5.1
Boost: 1.82.0
Goodman07
Post by Goodman07 »
sledgehammer_999 wrote: Mon May 29, 2023 1:31 pm You can assume as default the ones that the updater detects: The Qt5 build with LT-1.2
Thanks for the response. The last time I tried LT-2.0, I did not encounter any memory issues, but it took my torrents a long time to reach max speed. So I switched to LT-1.2 version and it resolved the issue.
I will stick with Qt5/LT-1.2 for now until it is discontinued, and then switch to Qt6/LT-1.2 afterwards.
Thanks,
