queued.svg icon broken on web ui
Lasdary
Post by Lasdary »
Since the update that changed the icons I see the 'broken image' symbol on the 'queued' torrents instead of the 'queued.svg' file.
I searched around the forum and subreddit but couldn't find anything like this.
I tried clearing cache and temp files on my browser; no luck - Same thing happens on a different pc so i doubt it's a local thing.
- qBittorrent v4.5.0 Web UI (64-bit)
- raspbian on a raspberry pi 4, 64 bit, up to date
- running on docker, using image lscr.io/linuxserver/qbittorrent:latest
Everything else works flawlessly as far as I can tell. It's just that resource file missing. Even after removing container, purging image, and redownloading from scratch. I searched for the file in the config folder but didn't find any .svg there.
I had no issues on the previous UI theme before the icons changed to their new version.
Chrome console says "Failed to load resource: the server responded with a status of 404 ()" at /images/queued.svg
Anything I can try? I don't even know where the ui files are or i'd try to check if it exists in the fs / manually download it from the repository.
Lasdary
Re: queued.svg icon broken on web ui
Post by Lasdary »
