Can't select a file
Coal Mine Canary
Can't select a file
Post by Coal Mine Canary »
I can't select a file to select or unselect from downloading in content tab.
I can, however use the buttons for select all and select none.
Any help?
Coal Mine Canary
Re: Can't select a file
Anyone?
Coal Mine Canary
Bump
Try downloading the qt60 version, or the normal one, in case you have the qt60 already.
Your settings should remain as they are.
https://www.fosshub.com/qBittorrent.html
Coal Mine Canary
That version doesn't seem to be able to be used as a portable app, which is a necessity for me.
