In the past when I needed to filter a search result to exclude two terms I would use the following in the Filter Search Results box:
^((?!foo|bar).)*$
Where foo and bar are the terms I want excluded.
However, this hasn't been working recently. Would anyone know whether this is an issue with the latest version of qBittorrent (4.5.0) or with the version of Python (3.11.1) that I am using?
Exclude Search Terms no longer work?
- MetalSpike
- Newbie
- MetalSpike
- Newbie
Re: Exclude Search Terms no longer work?
I've solved the the issue by right-clicking on the Filter Search Results box and selecting "Use regular expressions." Not sure how it became un-selected but hopefully the post helps someone else.
