qbittorrent stopped working
- Newbie
My qBittorrent program went from downloading at about 8Mb per second to about 8Kb per second. I had been using it for about 3 months with no problems the one day this. I turned all my fire walls off and uninstalled my antivirus software, uninstalled qBittorrent then re-installed it and the same thing. I tried a different torrent program Vuze and it works fine thought I really prefer qBittorrent. I wonder if anyone can help me. Thanks
- Newbie
Re: qbittorrent stopped working
At the bottom of your qBittorrent window you will see a small icon that looks like a speed indicator beside the connection status icon. Make sure you havent mistakenly switched it over to the alternative speed, just click on it, the speed hand should be facing to the right, if its to the left thats the alternative speed. If thats not it, go into Options and click on the Speed tab, and set your upload and download speeds to 0 (which is unlimited) or put what ever limit you want it at and also set the alternative speeds to where you want them at. Hope this helps.
I also had a similar issue with qbittorent and trying to figure out how to solve this issue on windows....fatandsweaty wrote: ↑Thu Jan 19, 2023 4:23 am My qBittorrent program went from downloading at about 8Mb per second to about 8Kb per second. I had been using it for about 3 months with no problems the one day this. I turned all my fire walls off and uninstalled my antivirus software,gbwhatsapp uninstalled qBittorrent then re-installed it and the same thing. I tried a different torrent program Vuze and it works fine thought I really prefer qBittorrent. I wonder if anyone can help me. Thanks
This happened to me as well. I have two pc´s, one desk side and one laptop, both connected via fibre ( 1Gb/s). I use Windows 11 with latest updates on both. I use HideAway from Firetrust as VPN-client. With VPN connected I get a speed of 600-900 kb/s on both pc´s.
qBittorrent has worked fine on both for some time. Now not working since some weeks.
- Newbie
I'm about to download qBitttorent again and see if anything has changed. I hope so because I don't like the VUSE torrent downloader I'm using atm
That's great! qBittorrent is a popular and reliable torrent client that many users prefer due to its simplicity and functionality. It's constantly being updated and improved, so there's a good chance that there have been some changes since you last used it.fatandsweaty wrote: ↑Tue Jan 24, 2023 4:11 am I'm about to download qBitttorent again and see if anything has changed. I hope so because I don't like the VUSE torrent downloader I'm using atm
When you download and install the latest version of qBittorrent, you'll likely find some new features, bug fixes, and performance enhancements compared to previous versions. It's always a good idea to keep your torrent client updated to ensure you have the best experience and security.Fm Whatsapp
