Windows does not allow me to download the app cuz virus
k2master
Post by k2master »
I would like to install qBittorent app: https://www.fosshub.com/qBittorrent.html qBittorrent Windows x64 version 4.5.0.
After 100% percent, it does not allow me to download the app, it says the followings:
Failed - Our system found a virus
screenshot: https://www.flickr.com/photos/197485875 ... h29tDGG9/
P.S. I have the same problem with other torrent app as well.
How could I solve this issue?
Re: Windows does not allow me to download the app cuz virus
Interesting. I went on the link, used Chrome, and no errors for me. If you go into Downloads in Chrome (Press CTRL+J), you can allow the file to be kept. But it's weird you are getting this virus warning, nothing for me over here.
k2master
Post by k2master »
Somehow I manage to download the installer.exe.
C:\Program Files (x86)\qBittorrent\qbittorrent.exe -> Enter, Error message pop up
this operation failed because the file contains a virus or unwanted malware
(Crude translation)
Then I hit ok and qbittorrent.exe dissapear from the folder. Only the
  • translations folder
  • qbittorrent.pdb file
  • qt.conf file
  • uninst.exe file
remains in the C:\Program Files (x86)\qBittorrent folder.
capitalpredict
Post by capitalpredict »
I have the same issue. Did you resolve it?
redactle unlimited
k2master wrote: Mon Jan 23, 2023 9:00 pm C:\Program Files (x86)\qBittorrent\qbittorrent.exe -> Enter, Error message pop up
What kind of antivirus do you use?
This whole process, even the installer... sounds suspicious.
Zoloft
Post by Zoloft »
There is nothing for qbt to "resolve." If you are downloading from a reliable source, like, HERE, it's a false positive. You simply have to override your AV and install the program.
