Hello,i can download the torrents without problem but i can't share them.
the files are "blocked" and inactive"!
Do you have a solution ?
in window defender qbittorent is allowed.
THANKS
Daniel
blocked
Re: blocked
- The default configuration relies on UPNP. If you do review the port actually in use (in preferences>connection) and make an online test o check if you're reachable. A site like https://www.yougetsignal.com/tools/open-ports/ is suitable
- If you didn't changed the DNS used by the computer running QBT it may be a lead. Try to you Google/Cloudflare/your flavor public DNS, restart the computer and check for a couple of torrent in QBT the status of the "tracker" tab. Anything else than "working" indicates a problem.
