files deleted by mistake
sturmtruppen
Post by sturmtruppen »
is it possible to put a confirmation prompt when deleting files in download or upload?
Is it possible to recover files deleted by mistake?
Bye and thank you.
unseen19
Re: files deleted by mistake
Post by unseen19 »
-The default when removing a torrent in QBT is to remove the loaded .torrent file and leave the downloaded file (matching the .torrent) on the drive. Unless the dedicated checkbox on the appearing window is checked.
- If the associated (downloaded) file is removed you can try a recovery tool, but in essence it's gone
sturmtruppen wrote: Thu Feb 23, 2023 11:52 am Hi,
Bye and thank you.
By default, there is confirmation.
In settings, just scroll down as it pops up and "Show confirmation when deleting torrents" should be checked.
