Use qBittorrent Enhanced Edition v4.5.2.10.
MacOS Ventura 13.3.
Unable to fit columns to width.
The option does not work.
It is only possible to make it wider, but not narrower.
How to solve a problem?
Re: Unable to fit columns to width.
This project has nothing to do with "qBittorrent Enhanced Edition".
Please report this on their bug tracker: https://github.com/c0re100/qBittorrent- ... ion/issues
(We are not related to them in any way, it is a fork unrelated to the original project. The name choice is, unfortunate.)
Thanks for the reply Peter.
But a similar problem manifests itself with the original version of the client.
They don't respond to the bug tracker.I asked there for a long time.
https://github.com/c0re100/qBittorrent- ... ssions/420
Use official qBittorrent v4.5.3 and 4.6.0.
MacOS Ventura 13.4.
Columns cannot be made already of a certain value.
In the old version 4.3.9, column widths could be reduced.
Checked in version 4.5.3 for Windows - everything works. Doesn't work on Mac version.
May need to reset the settings or delete the settings file. Where is he located?
MacOS Ventura 13.4.
Works fine for me.
qBittorrent v4.5.2
macOS Ventura v13.4
Last time I had an unfixable issue with qBittorrent it took trashing every little trace of it.
Use FindAnyFile and click option as you click 'Find' so as to search as root.
qBittorrent v4.5.2
macOS Ventura v13.4
thanks a lot bro!Fuga wrote: ↑Wed May 31, 2023 9:09 am Last time I had an unfixable issue with qBittorrent it took trashing every little trace of it.
That helped.
Very good. Thanks for letting us know.kb0000001 wrote: ↑Thu Jun 01, 2023 2:05 pmthanks a lot bro!Fuga wrote: ↑Wed May 31, 2023 9:09 am Last time I had an unfixable issue with qBittorrent it took trashing every little trace of it.
That helped.
Fuga wrote: ↑Thu Jun 01, 2023 3:07 pmVery good. Thanks for letting us know.kb0000001 wrote: ↑Thu Jun 01, 2023 2:05 pmthanks a lot bro!Fuga wrote: ↑Wed May 31, 2023 9:09 am Last time I had an unfixable issue with qBittorrent it took trashing every little trace of it.
That helped.
- 23535.jpg (349.53 KiB) Viewed 1246 times
