Torrent files not showing up when dloaded
gopens25
Post by gopens25 »
I'm using version 4.5.2, just installed it yesterday and am having a wierd issue. I've used torrent clients in the past, including this one, so I kind of know what I'm doing but this is a headscratcher.
I download a torrent file and it isn't there. I have checked the location folder in the settings and it is definitely pointing to the correct place, and in Chrome it is on the bottom where completed downloads show up, but then before I can do anything it says "removed"
Yesterday I was able to download a tracker and start it, but when it finished the torrent file was gone and it downloaded into a folder I did not select. The correct folder shows in the options, but it downloaded into a different one. I do not have the option for moving completed torrents to a different folder enabled.
So I guess I'm having a couple of problems. I hope someone can help and that it is an easy fix. Thanks in advance
