Search doesn't work
van
Search doesn't work
Post by van »
Hi
MacBook Air M1 Silicon - Ventura 13.3.1 - Qbittorrent 4.5.2 - using Private Internet Access VPN
Reinstalled Qbittorrent after updating to Ventura. (Was working fine under Monterey)
Works with magnet links and seeding fine.
Search plug-ins show as installed and enabled.
Search just fails with an orange triangle "!". No error in logs.
Have tried combinations of:
Re-starting
Deleting and installing trackers (use the weblink method to the github links - install and enable ok)
Installing from local saved .py files
Re-installing Qbittorrent
Updating within search (loads default search plug-ins)
Any ideas welcome!
Thanks
EDIT/UPDATE
Set up and added Jackett as a URL link and that works so going with that for a solution
