downloading
downloading
For some reason nothing wants to download, it just gets stuck on retrieving meta data, i had something download and then i paused it and after resuming it was just stuck on stalled, i reinstalled still nothing, i tried multiple different torrents to see maybe its just that one thing but its everything
Re: downloading
What are you trying to download?jimmyrust wrote: ↑Tue May 23, 2023 10:31 pm For some reason nothing wants to download, it just gets stuck on retrieving meta data, i had something download and then i paused it and after resuming it was just stuck on stalled, i reinstalled still nothing, i tried multiple different torrents to see maybe its just that one thing but its everything
If it's some public torrent, you need to have an open port and you must not be firewalled and.. a lot of things to be able to download.
1) Try downloading a normal torrent, see, if issue persists: https://ubuntu.com/download/alternative-downloads
Scroll down and grab the Ubuntu torrent file.
2) If it's a public torrent you can always add trackers to it.
- Go here: https://github.com/ngosang/trackerslist
- Click "trackers_all.txt" for example
- Hit the "Raw" button on top-right, to have an easily copyable list.
- Now go to qBittorrent, click on your torrent, then Trackers on bottom. Right-click, Add Trackers, and put in the list.
This helps - IF there are seeders AND you are experiencing issues because the trackers are unavailable/down.
