Are there any important reasons why I should upgrade to the latest version?
miracles
Post by miracles »
Using qBittorrent v4.4.5 Win 10 x64
Are there any important reasons why I should upgrade to the latest version, I'm mainly thinking about stability, security and performance?
I hesitate because of the extremely ugly GUI and icons in the newer versions starting with the 4.5.0 release.
Re: Are there any important reasons why I should upgrade to the latest version?
No.
Only need to use the latest version if you use the WebUI/-nox version; but if you do that, you should not expose it to the public internet anyway.
miracles
Post by miracles »
Thank you Peter for a very good and clarifying answer, it is much appreciated!
Best regards,
miracles
