qBittorrent.ini not being parsed after fresh install
13gears
Post by 13gears »
I saved the ini file to backup the settings. Installed freshly updated client, merged (overwrite) the backup ini file onto existing... and nothing, no change. So, what gives?
Re: qBittorrent.ini not being parsed after fresh install
There are multiple folders.
%APPDATA%\qBittorrrent
%LOCALAPPDATA%\qBittorrrent
You need to save both, and replace both if you migrate/reinstall.
13gears
Post by 13gears »
Thanks Pete, just for the record I figured it out by downloading and installing a variant distro of the program. Then everything clicked in just fine.
