Stalled status
Parzival
Stalled status
Post by Parzival »
Hello
I've installed qBittorrent on Debian, created a private torrent file, and uploaded it to the itatorrents.xyz tracker. Afterward, I downloaded the torrent file from the tracker and attempted to seed it. The torrent file is in the same folder as the video file. However, the problem is that it's not entering the seeding mode; instead, it's getting stall
Router port are forwarded
No firewall
Is that the correct procedure to first seed a file?
Than you
Re: Stalled status
Stall is fine. Stall means no traffic.
If you click the torrent in the list, then Trackers on bottom, you can see tracker status there.
