I have been using qbittorent along with Sonarr and Radarr in order to get movies for a Plex library, everything has been working fine up until recently when all trackers suddenly stopped working. Some say "skipping tracker announce (unreachable)" others say "timed out" and some "host not found (authoritative)". I have been trying everything I can think of, I don't believe it's a DNS resolving issue because if I attempt to ping the tracker domains even from within the docker container of qbittorent and they ping just fine, how can I resolve this issue? I am running qbittorent 4.5.4 in a docker container using the bridge network, the correct port is forwarded through the router and uPnP is disabled. What should be my next steps to troubleshoot this issue? Thanks in advance.
I tried pinging some of the trackers which weren't working using nslookup and they successfully resolve the address so now I am fairly certain it is not a DNS issue
Public ones often go offline (sometimes, 100% of the added public trackers are dead), that's why people use projects like https://github.com/ngosang/trackerslist
