QBT 4.5.4 will not save files where I set it to. SOLVED!!!
DickDawson
Post by DickDawson »
Anyone having this issue or know how to fix? Nothing I do will make qBittorrent download/save files to the folder I want it to. I set it in settings and all but nothing I do helps and it just sends all files to my downloads folder. Screen shot of settings included.
QBT settings image 1.PNG (39.3 KiB) Viewed 1092 times
ItWasSooted
Re: QBT 4.5.4 will not save files where I set it to
Post by ItWasSooted »
See if the following thread has the answer.
viewtopic.php?p=40281&hilit=save#p40281
DickDawson
Thanks! That was it. I got a little lost in that jason file but I said screw it, deleted it and when I relaunched qBittorrent I reselected the folder I wanted and the watch folder and now it finally works again! Thanks again.
