how can I migrate all my in-progress torrents from one computer to another one? I would like to migrate torrents/files only! Not configuration files of qBittorrent. (I used different installation file (qt6) on new machine than on old machine so I guess copying configuration files might cause troubles, and generally I better setup configuration on the new machine from the scratch rather than copying the old one. My question in about torrents/files only).
Thanks.
Migration to new comp
Re: Migration to new comp
I found the solution - copying only this folder C:\Users\"UserName"\AppData\Local\qBittorrent\ into the new machine will transfer the details about the torrents from old machine to new machine. Configuration will not be migrated. Torrents will start to download files from beginning into the originally set folder.
