I have a Macbook Pro running Ventura. I run an older version of qBittorrent 4.3.2 because newer versions have problems with Ventura. I haven't had ANY problems with this version. Have been running it for a long time.
I had torrents loaded and lost power. When I booted back up qB locked up. All the loaded torrents were displayed.
I have tried deleting the program and reinstalling it.
I have tried upgrading to a newer version.
I have tried upgrading to a newer version and then deleting it and reinstalling the original version
I tried deleting all the torrents from my download folder, but they still appear in qB
When I reload it or upgrade to a newer versions, the loaded torrents show up. Once I click on the qB icon to open it, the wheel spins and nothing works. I get the "qB not responding" message. I feel like if I could get it to open without the torrents loaded into it, the problem would be solved, but it freezes before I can delete them, and when I trash the program, empty the trash, shut down, and then reload the program on boot up, the torrents still show up.
