Settings after upgrade
rigsby
Post by rigsby »
Not a big deal, but after upgrading to v4.6 (from the previous version) all the columns were in a completely different order with some added and some (I used) missing.
Just letting the respective parties know, that's all.
zika
Re: Settings after upgrade
Post by zika »
Yea, same.
Had to copy/paste prev exe, make screenshots of all the columns and then upgrade.
PriitUring
Post by PriitUring »
You should fix the title to be more obvious:
"Columns order and visibility gets reset after upgrading".
This Qt dependency related issue is a known old issue. It happens even with older qBittorrent versions if you try switching qBit installers using Qt5 and Qt6.
https://github.com/qbittorrent/qBittorrent/issues/17145
Since Qt5 and old Windows 7 & 8.1 isn't supported anymore and so there's less qBit installer choices, then maybe resetting columns happens less often than before. Still there's always a chance that this will happen again someday whenever qBittorrent is used with some newer major Qt version.
Bug reports in the future please post in GitHub, because forum seems to be read less often.
