Messed Up Columns After 4.6.0 Update
DNeed
Post by DNeed »
I just updated to v4.6.0 and all my columns are messed up. I can no longer make them as small as they used to be. How can I fix this?
This is what is looked like in v4.5.5
DNeed
Re: Messed Up Columns After 4.6.0 Update
Post by DNeed »
Can anyone help? Is this expected in 4.6.0?
DNeed
Post by DNeed »
Looks like 4.6.0 installs QT6.4.3, which explains why this is happening. Hoping they can fix this. I rolled back and staying there until the columns are fixed.
JJayzX
Post by JJayzX »
I was hoping that 4.6.1 would fix this but nope.
dsneed
Post by dsneed »
Just bring back QT5!
DNeed wrote: Fri Oct 27, 2023 4:21 pm Looks like 4.6.0 installs QT6.4.3, which explains why this is happening. Hoping they can fix this. I rolled back and staying there until the columns are fixed.
I mean in the original post you mentioned you can't make them small.. but I can?
dsneed
Post by dsneed »
I tried v4.6.1, but still can't make the columns any smaller :'(
JJayzX
Post by JJayzX »
Peter wrote: Wed Nov 22, 2023 10:06 pm
It doesn't affect everyone but it's very annoying and I've been staying on previous version. Would be nice to know what causes it.
JJayzX wrote: Wed Nov 29, 2023 12:54 am It doesn't affect everyone but it's very annoying and I've been staying on previous version. Would be nice to know what causes it.
Yeah but I can't figure which users it affects.
Like I am on Windows 11, it's Qt6 + latest version and I can make the columns tiny.
But for some, it doesn't work.
What OS do you guys use? Where's the difference?
dsneed
Post by dsneed »
Peter wrote: Wed Nov 29, 2023 6:11 pm
Windows 11 Pro 64-Bit 23H2 Build 22631.2787
Are you using DPI scaling by any chance?
dsneed
Post by dsneed »
No. DPI scaling is 100%.
Resolution is 1920x1080
dsneed wrote: Wed Nov 29, 2023 6:52 pm No. DPI scaling is 100%.
Suuuper weird.
So you move your mouse to the column, it turns into this other mouse and you just can't make it really narrow?
And you are on Qt6, 4.6.2?
"qbittorrent_4.6.2_lt20_qt6_x64_setup.exe"
dsneed
Post by dsneed »
Peter wrote: Wed Nov 29, 2023 7:33 pm
Suuuper weird.
I just tried QB 4.6.2 and still the same problem. Even if I install any previous QT6 version, I have the issue. The issue is QT6, not QBittorrent itself. I would love to see QT5 brought back, at least until the QT6 issue is resolved.
