qbittorrent-nox 4.5.4 looses all config settings after reboot
polar
Post by polar »
ubuntu 23.10 mantic Linux sandersuperserver 6.5.0-10-generic
qbittorrent-nox -v : qBittorrent v4.5.4 (probably installed by apt package manager)
Guys,
I have a really weird problem here. Maybe you can make something out of it.
When I enter the settings in the web GUi of qbittorrent-nox and I configure stuff, login, passwd, interface, device, ip , download, download temp,
any thing it doesn't matter what, it works.
However, when I reboot the server (pc) or just restart the daemon by 'systemctl restart qbittorrent-nox'
the application looses all config. It resets to default like it has just been installed with default admin login.
O what could that be? Is the application not able to save the config? If so, why isn't there an error popup?
Has anyone experience with this, and how to get rid of this issue?
Thanks for any help. I wasn't able yet to find anything useful searching the net.
Bye. ;)
qbittorrentX0Xdude
Re: qbittorrent-nox 4.5.4 looses all config settings after reboot
Post by qbittorrentX0Xdude »
Same issue here,
lost all my torrent data from the last few days :(
I'd highly recommend using the 'qbittorrent-nox-static' project instead of the APT versions:
https://github.com/userdocs/qbittorrent-nox-static
It just works. (For me at least.)
Ps.: This is for people who use the WebUI. Since it's a -nox build, it does NOT have a desktop graphical interface whatsoever. Not to say you can't use it as a desktop torrent client, you just have to control it over the WebUI.
