winget still showing v4.6.0
drghughes
Post by drghughes »
The winget installation/upgrade system hasn't been updated with the v4.6.1 version.
It is still showing v4.6.0:
>winget show qBittorrent.qBittorrent
Found qBittorrent [qBittorrent.qBittorrent]
Version: 4.6.0
Publisher: The qBittorrent project
Publisher Support Url: https://github.com/qbittorrent/qBittorrent/issues
Author: Sledgehammer999 <[email protected]>
Christophe Dumez <[email protected]>
Description:
  qBittorrent is a bittorrent client programmed in C++ / Qt that uses libtorrent (sometimes called libtorrent-rasterbar) by Arvid Norberg.
  It aims to be a good alternative to all other bittorrent clients out there. qBittorrent is fast, stable and provides unicode support as well as many features.
License: GPL-3.0
License Url: https://github.com/qbittorrent/qBittorrent/blob/master/COPYING
Copyright: Copyright © 2006-2023 The qBittorrent project
Release Notes:
  qBittorrent v4.6.0 was released.
  A lot of work has been done for version 4.6.0. The changelog below includes the most notable changes for end users along with the author for each change. Also, I want to thank all the users, like thalieht and xavier2k6, who constantly help with testing PRs and doing bug triaging.
  WINDOWS: Only Windows 10+ is now supported.
  SECURITY NOTICE: WebUI users YOU MUST change the default Webui credentials (aka "adminadmin") when exposing the WebUI to the Internet. There are reports(1, 2, 3, 4) that this is possibly exploited in the wild. This will be remedied in a followup release where the default credentials will be disabled and a credentials change will be forced.
  macOS: Builds are self-signed now. It should help with macOS permissions dialogs.
  v4.6.0 changelog:
  - FEATURE: Add (experimental) I2P support (glassez)
  - FEATURE: Provide UI editor for the default theme (glassez)
  - FEATURE: Various UI theming improvements (glassez)
  - FEATURE: Implement torrent tags editing dialog (glassez)
  - FEATURE: Revamp "Watched folder options" and "Automated RSS downloader" dialog (glassez)
  - FEATURE: Allow to use another icons in dark mode (glassez)
  - FEATURE: Allow to add new torrents to queue top (glassez)
  - FEATURE: Allow to filter torrent list by save path (Tom)
  - FEATURE: Expose 'socket send/receive buffer size' options (Chocobo1)
  - FEATURE: Expose 'max torrent file size' setting (Chocobo1)
  - FEATURE: Expose 'bdecode limits' settings (Chocobo1)
  - FEATURE: Add options to adjust behavior of merging trackers to existing torrent (glassez)
  - FEATURE: Add option to stop seeding when torrent has been inactive (Christopher)
  - FEATURE: Allow to use proxy per subsystem (glassez)
  - FEATURE: Expand the scope of "Proxy hostname lookup" option (glassez)
  - FEATURE: Add shortcut for "Ban peer permanently" function (Luka Čelebić)
  - FEATURE: Add option to auto hide zero status filters (glassez)
  - FEATURE: Allow to disable confirmation of Pause/Resume All (glassez)
  - FEATURE: Add alternative shortcut CTRL+E for CTRL+F (Luka Čelebić)
  - FEATURE: Show filtered port numbers in logs (Hanabishi)
  - FEATURE: Add button to copy library versions to clipboard (Chocobo1)
  - BUGFIX: Ensure ongoing storage moving job will be completed when shutting down (Chocobo1)
  - BUGFIX: Refactored many areas to call non UI blocking code (glassez)
  - BUGFIX: Various improvements to the SQLite backend (glassez)
  - BUGFIX: Improve startup window state handling (glassez)
  - BUGFIX: Use tray icon from system theme only if option is set (glassez)
  - BUGFIX: Inhibit system sleep while torrents are moving (Sentox6)
  - BUGFIX: Use hostname instead of domain name in tracker filter list (tearfur)
  - BUGFIX: Visually validate input path in torrent creator dialog (Chocobo1)
  - BUGFIX: Disable symlink resolving in Torrent creator (Ignat Loskutov)
  - BUGFIX: Change default value for file pool size and stop tracker timeout settings (stalkerok)
  - BUGFIX: Log when duplicate torrents are being added (glassez)
  - BUGFIX: Inhibit suspend instead of screen idle (axet)
  - BUGFIX: Ensure file name is valid when exporting torrents (glassez)
  - BUGFIX: Open "Save path" if torrent has no metadata (Xu Chao)
  - BUGFIX: Prevent torrent starting unexpectedly edge case with magnet (Xu Chao)
  - BUGFIX: Better ergonomics of the "Add new torrent" dialog (Xu Chao, glassez)
  - WEBUI: Add log viewer (brvphoenix)
  - WEBUI: WebAPI: Allow to specify session cookie name (glassez)
  - WEBUI: Improve sync API performance (glassez)
  - WEBUI: Add filelog settings (brvphoenix)
  - WEBUI: Add multi-file renaming (loligans)
  - WEBUI: Add "Add to top of queue" option (thalieht)
  - WEBUI: Implement subcategories (Bartu Özen)
  - WEBUI: Set "SameSite=None" if CSRF Protection is disabled (七海千秋)
  - WEBUI: Show only hosts in tracker filter list (ttys3)
  - WEBUI: Set Connection status and Speed limits tooltips (Raymond Ha)
  - WEBUI: set Cross Origin Opener Policy to same-origin (Chocobo1)
  - WEBUI: Fix response for HTTP HEAD method (Chocobo1)
  - WEBUI: Preserve the network interfaces when connection is down (Fabricio Silva)
  - WEBUI: Add "Add Tags" field for RSS rules (Matic Babnik)
  - WEBUI: Fix missing error icon (Trim21)
  - RSS: Add "Rename rule" button to RSS Downloader (BallsOfSpaghetti)
  - RSS: Allow to edit RSS feed URL (glassez)
  - RSS: Allow to assign priority to RSS download rule (glassez)
  - SEARCH: Use python isolate mode (Chocobo1)
  - SEARCH: Bump python version minimum requirement to 3.7.0 (Chocobo1)
  - OTHER: Enable DBUS cmake option on FreeBSD (yuri@FreeBSD)
  - OTHER: Numerous code improvements and refactorings (glassez, Chocobo1)
Documentation:
  Wiki: https://github.com/qbittorrent/qBittorrent/wiki
Tags:
  bittorrent
  bt
  download
  magnet
  p2p
  share
  sharing
  torrent
  upload
Installer:
  Installer Type: nullsoft
  Installer Url: https://sourceforge.net/projects/qbittorrent/files/qbittorrent-win32/qbittorrent-4.6.0/qbittorrent_4.6.0_lt20_qt6_x64_setup.exe/download
  Installer SHA256: 0512b822bb6736e75277a3d1e859514c4dee8a3bb982fd536307935b23cbb972
  Release Date: 2023-10-22
