Good evening to all,
I have upgraded QB to 4.62, unistalling previously the old version and deleting all settings.
After installed new release, in research is working "only" TNT Village research engine; do you can give me a solution to resolve this problem?
Thanks in advance.
Research problem
Re: Research problem
If you enable Execution Log in View and then check Log tab above your transfers.
Hi Peter,Peter wrote: Tue Nov 28, 2023 10:41 pm If you enable Execution Log in View and then check Log tab above your transfers.
Can you attach images for best instructions?
Thanks in advance.
Attached screenshot of a research "Pink Floyd". Like just explained is working only TNTVillage.org.
From screenshot do you can see a my error in settings?
- Immagine-research.png (191.08 KiB) Viewed 545 times
