SmartApp Control
zamarax
SmartApp Control
Post by zamarax »
Hi, any chance of getting the application signed? Windows SmartApp control blocks it entirely and the only way to turn off SmartApp control is to reset my whole system.
https://support.microsoft.com/en-au/top ... 98afdb7003
Re: SmartApp Control
You can just click the dialog option on top and allow this file only. No need to mess with the system.
But to answer the question: It's really expensive to get code signing done. The certs are really expensive.
It's around 200-300$ a year or so on the low-end.
zamarax
Post by zamarax »
I was able to get around it, there is no easy way to disable 'SmartApp Control' but...there is a registry hack that you can do to allow it to install, it reverts once you restart but it's enough to allow me to apply updates.
