Qbittorent doesn't start before login - debian
alexnt
Post by alexnt »
I have set up a debian vm as a media pc(qbt & plex) but I noticed that qbt doesn't run until I login to desktop or at least cannot access the webui from my win10 machine until I login debian user first.
I have already added qbt to the startup applications in this vm. I would, also, prefer the user not to autologin.
Is there any way I can make this work?
GreatKaruboniru
Re: Qbittorent doesn't start before login - debian
Post by GreatKaruboniru »
loginctl enable-linger
if you are using systemd user instance.
alexnt
Post by alexnt »
GreatKaruboniru wrote: Sat Dec 09, 2023 8:35 am
Isn't this used after user logout? I need something to run automatically qbt without login user first.
https://docs.oracle.com/en/operating-sy ... -you-begin
unseen19
Post by unseen19 »
QBT is a user process so by default you need to open a session and QBT and the configured WebUI will start.
You can launch it system side but extra config is needed, is this the path you took ?
https://github.com/qbittorrent/qBittorr ... -or-newer)
