qB freezes, unable to force-quit
abb37268
Post by abb37268 »
qB freezes when trying to move files or just quit, unable to force-quit even by "Force Quit"app or Activity Monitor.
What should I do?
If qB freezes, it heavily slow down the speed of storages, including OS HDD.
Environment
Mac OS 10.12 Sierra
qB v4.2.0
Re: qB freezes, unable to force-quit
It seems like you are trying to kill qbitttorrent when its doing heavy lifting.
You should limit download speed and also the concurrent download count (ie.: how many torrents download at the same time) so your HDD can keep up.
Also, I do NOT recommend downloading to the SSD inside a Mac because Macs have soldered SSDs. And once you kill it, it's a really expensive replacement.
