PIA VPN Qbittorrent Binding
Freelife2021
Post by Freelife2021 »
How do I bind PIA VPN to Qbittorrent? I can not find relevant correct info on the newest versions of each.
On windows 10 in the USA
NXZ
Re: PIA VPN Qbittorrent Binding
Post by NXZ »
1- Close qBittorrent.
2- Connect your computer to PIA VPN.
3- Start qBittorrent.
4- Go to: Tools > Options > Advanced > Network interface.
5- Open the dropdown menu next to Network interface.
6- Select the interface referring to PIA (example: wgpia0).
7- Click on OK.
8- Restart qBittorrent.
If you can't find the interface, go into PIA's client and change the Protocol.
OpenVPN for example uses a separate interface, while Wireguard does not.
Just switch around the protocols and see if it pops up. Make sure to restart qBittorrent between tries.
The protocol should not affect your speeds.
(They do differ, and some are faster than others, but just for internet use we can say it's the same. Like if you were to push insane speeds, Wireguard would win vs. OpenVPN. But over the internet, no difference.)
