Auto shutdown after downloads completed
ExtremeN
Post by ExtremeN »
I can't find this option in the Linux version. I'm using qBittorrent-nox. If official support is not there, is there a way to achieve this? I'm still learning Linux.
rdalek
Re: Auto shutdown after downloads completed
Post by rdalek »
I'm not sure what you mean by the "nox" part but on mine, it is under Tools in the menu at the top. It's the bottom option 'on downloads done'. If by nox you mean you have no GUI, there is likely a config file option that you can edit. I looked in places I'd expect it to be but can't find a config file with that option. The config file I found is located here: /home/<user name>/.config/qBittorrent/qBittorrent.conf That file has some very long non wrapped lines. Be careful editing it. It would be a good idea to make a backup of that file before doing anything. I looked in a few other places for a config file but didn't find anything. I'm not sure where else to look.
The option is there with a GUI. Without, I'm not real sure. It's likely doable but no idea where. I couldn't even find a command line option.
androi
Post by androi »
I found the option in the [Preferences] section of the /home/<user name>/.config/qBittorrent/qBittorrent.conf file:
Downloads\AutoShutDownqBTOnCompletion=true
I set it with the GUI, and the qBittorrent-nox observes it.
