Unable to set Share Ratio on individual torrents
greendrive
Post by greendrive »
Even though the option to limit share ratio on individual appears in the webUI, I'm not able to get it to take affect.
I have one torrent currently set with a share ratio that I'm unable to clear, and I've also tried setting a ratio on other torrents, and can't get it to take effect. So it seems the functionality worked for me at some point, because I have that one torrent stuck with an individual share ratio that I'm unable to change.
I'm posting on the Docker board since my torrent server is running using the lscr.io/linuxserver/qbittorrent:latest container. I have a feeling this might be permissions related somehow, but I don't know where I need to check. When I try to adjust the share ratio in the webUI, there are no log entries generated in /config/qBittorrent/logs/qbittorrent.log. Let me know if there is more detail I need to post to help figure this out!
