WebUI, login credentials
Arelius
Post by Arelius »
Hi all,
Is it possible to go around the WebUI login page by using any of these?
- WEBUI_USERNAME=
- WEBUI_PASSWORD=
- QBITTORRENT_WEBUI_USERNAME=
- QBITTORRENT_WEBUI_PASSWORD=
Re: WebUI, login credentials
- Could you clarify what do you mean by "go around"?
- Also, each Docker qBittorrent "distribution" is different, there is no official version. So each will differ in behavior.
Arelius
Post by Arelius »
Peter wrote: Wed Apr 10, 2024 10:02 am - Could you clarify what do you mean by "go around"?
I don't want to get asked for user/pass is what I mean.
I have not seen any builds with these commands (not that I remember at least) so I tried adding them to Docker compose but none of them worked so I though maybe it's just not possible(?).
Is there any build out there that supports such behavior?
It would be a BIG security flaw.
Simply go into settings and you can enable whitelist. Like you can whitelist an IP for example. If it's on the internet and you don't have a static IP, you can always set up SSH port forward and then use the local IP (like 127.0.0.1) as whitelist.
Arelius
Post by Arelius »
Peter wrote: Wed Apr 10, 2024 1:56 pm It would be a BIG security flaw.
Under which tab can I find that setting? Maybe I'm blind :o
