Problem downloading torrent files
roballen
Post by roballen »
Hello, When downloading files, it gets stuck at "Downloading metadata" and cannot be downloaded. I tested these torrents on another machine and everything works fine. Is it because my device has a problem?
Re: Problem downloading torrent files
If it says metadata, it means your client is trying to download the torrent file from the other peers because it's a magnet link. But it can't connect to them.
Look up port forwarding and make sure you don't have qBittorrent firewalled.
bob2306
Post by bob2306 »
Lack of port forwarding will affect only a tiny minority of cases, it's very unlikely to be the cause of a systematic problem.
LilTroy
Post by LilTroy »
roballen wrote: Tue Apr 16, 2024 1:50 am Hello, When downloading files, it gets stuck at "Downloading metadata" and cannot be downloaded. I tested these torrents on another machine and everything works fine. Is it because my device has a problem?
What Peter said. Are you by chance using a VPN on your main machine? Some providers have designated P2P file transfer servers. Others don't allow torrenting at all (they actively block it). I ran into this issue once before with a previous service provider I tried so just thought I'd mention it.
