qBittorrent display the progress bar imprecise
- Newbie
Am I crazy or did qBittorrent display the progress bar better in previous versions? I'm currently using v4.5.5 (Qt6 and libtorrent 2) and it seems like the bar only jumps about every 2-3 percent. At first glance I thought there was no progress at all until I looked at the percentages and realized they were still moving. Why was the progress bar downgraded like that? The graphical view is now practically useless for intuitive speed determination.
Re: qBittorrent display the progress bar imprecise
I mean, you can check...
1) You can check by downloading 4.5.5 and test.
2) You can check on the Github site: https://github.com/qbittorrent/qBittorrent
Go on the site, click "Commits" and you can see what went into it between 4.5.5 and 4.6.5.
3) You can check out the git repo and then use "git log --pretty=oneline release-4.5.5...release-4.6.5" to check the commits.
I looked for "progress" or progress bar but nothing in the logs.
