SOLVED - Version 4.6.7 x64 won't install
Castellar
Post by Castellar »
It gets stuck on the uninstall part. I can't manually uninstall Version 4.6.6. either.
Please help, thanks.
Castellar
Re: Version 4.6.7 x64 won't install
Post by Castellar »
Solved. It was due to new Antivirus interference.
Re: SOLVED - Version 4.6.7 x64 won't install
Thanks for letting us know what caused the issue!
