Good evening I have a problem with qbittorrent.
Andrei2003
Post by Andrei2003 »
I use 2 private trackers, only with an anime tracker I have this problem, it gives me an error unspecified system error I can't download anything, how can I fix it so I can download. :'(
Re: Good evening I have a problem with qbittorrent.
Which anime tracker? It's not illegal to say tracker names.. :)
Andrei2003
Peter wrote: Wed Oct 02, 2024 12:36 am Which anime tracker? It's not illegal to say tracker names.. :)
Anime torrents I can't download anything. other sites ie trackers work. and I have no problems with Filelist and speedapp.
The website is called "Anime torrents"?
Andrei2003
Peter wrote: Wed Oct 02, 2024 10:07 am The website is called "Anime torrents"?
yes it is similar to Anime kage. only with anime torrents. ro i can't download anything from their site. it gives me stalled. when i download
postcd
Post by postcd »
You can contact the tracker users or operators if they have the same problem, or you can try other bittorrent client what will happen.
Andrei2003
postcd wrote: Fri Oct 11, 2024 8:48 am You can contact the tracker users or operators if they have the same problem, or you can try other bittorrent client what will happen.
I succeeded with a Windows reinstall. could also go by clearing settings. at qbittorrent. it was just that tracker. but I solved it.
