Cleaning up non working trackers. Peers tab as an indicator?
postcd
Post by postcd »
Hello,
inside qbt 5.0.0 one can delete tracker across all torrents. Thank you.
My idea is to run qbittorrent for lets say 10 or more days and then click tracker in the sidebar, click torrent, trackers tab and check "Peers" column. If the column is "Not available" then I assume that for last 10+ days qbt have been unable to connect the tracker to get peer count? I can visit that tracker website or remove it right away by right clicking the tracker in the sidebar and selecting to remove it (note that it will remove both http/s and udp so possibly verify that both protocols does not work)
Any feedback to this or better/safer way to cleanup non working trackers?
