5.0 update broke 'also remove the content files'
229Mick
Post by 229Mick »
I've been using qBittorrent for a while, it recently updated to v 5.0 and though I'd previously had the option checked to 'also remove the content files' when removing a torrent. It's still checked but today I realized that it's not actually removing the files anymore.
I tried doing one and turning it off, then doing another and turning it back on and it still fails to delete the files.
Is this a known bug in 5? Anything I can try to get it resolved?
Thanks!
LilTroy
Re: 5.0 update broke 'also remove the content files'
Post by LilTroy »
229Mick wrote: Wed Oct 16, 2024 7:16 pm I've been using qBittorrent for a while, it recently updated to v 5.0 and though I'd previously had the option checked to 'also remove the content files' when removing a torrent. It's still checked but today I realized that it's not actually removing the files anymore.
Thanks!
The issue is known about. Here's the solution.
229Mick
Post by 229Mick »
Perfect, Thank you!
