plugins
graham
plugins
Post by graham »
Downloaded new 5.0 version and all the plugins are not supported any suggestions please
slipwaycaring
Re: plugins
Post by slipwaycaring »
Please try this method and see. Verify that the plugins you are using are compatible with the new version. Some plugins may not have been updated for 5.0 yet. Sometimes, reinstalling the plugins can resolve compatibility issues. Try removing and thenbitlife reinstalling them.
graham
Re: plugins
Post by graham »
when i'm using the search plugins button all are not recognised Nothing !!!
graham
Re: plugins
Post by graham »
Nothing is supported
Re: plugins
Read this post and replies please: https://www.reddit.com/r/qBittorrent/co ... ported_no/
I just went to Search, clicked Search Plugins, and pressed Check for updates.
Like I have done for years, since search was introduced.
Behold, a dozen of search plugins auto installed.
